Custome 360/VR Camera Mount
Hours later... the other mount arrived. Using two CGO3+ mounts is a clean and professional look. It's also easier to hold the 1/4" for the camera.
I'm totally nerding out now... I mounted two 360 cameras on an H at the same time. This setup is to heavy for the gimbal and it was shaking all over the place since it wasn't balanced well. The video takes a long time to process but I will upload the vid as soon as it's done so check back for updates.
So does the 360 store the data on a sd card. What king of reception range do you get streaming to a phone?
the Fly360 Stores the data in an internal card that is not removable. The 360 Action Cam uses a micro SD card that is removable. Both of the cameras are controlled via wifi, but I didn't bother with that since I was focused on flying the hex. I just turn them on and let them record and then review the footage after the flight.
Post editing got it straightened out right, Thanks! Looks good but does need a gimbal to make it better and if the bluetooth connection was able to be stronger so it would stay linked or a way to make it compatible to the ST16 would make this a cool addition. I wonder if the older CG02 or CGO3 gimbal could be adapted to these cameras somehow? 3d printing a shell to snap it into and then pull the guts out of the CG0 camera and replace with this? However the back camera facing the gimball would be blocked.
daps20
