Data Pilot Planner Windows: Missing Camera Model E20Tvx
I just installed Data Pilot Planner v2.1.22 form here: Download – Yuneec
Unfortunately, the Camera tab does not contain my camera model E20Tvx
On the ST16E handheld the Data Pilot contains said camera model - E20T and E20T-Thermal.
How can it be added to the windows version?
@Enrico Jorysch may be the best to address this.
For V2.1.22 the version numbers are the same for the ST16E controller/hand held DataPilot and the DataPilotPlanner for the computer.
For the ST16E-RTK DataPilot there was apparently a later v2.2.28 issued. There are copies of the DataPilot 2.2.28 available, but I do not see a copy of the DataPilotPlanner of the same version number, or any version higher than the V2.1.22 already linked above.
Does anyone know if there is a version of DataPilotPlanner higher than V2.1.22, and if so, can you make a copy available?
It would also be good if someone could address whether the DataPilot and DatapilotPlanner are the same for H520E and for H520E-RTK.
Does anybody know at least, how to add the Camera as Custom?
The Sensor Width and Height and Focal Length for the IR Camera are not given in the data table?
Meanwhile I was able to reverse engineer the parameters from the apk...
C:
  CameraMetaData::CameraMetaData
            (pCVar1,(QString *)&stack0xffffff90,7.68,6.144,640.0,512.0,13.0,true,true,1.5,
             (QObject *)param_1);
            (pCVar1,(QString *)&stack0xffffff94,5.64144,3.1784,1920.0,1080.0,3.5,true,true,1.3,
So
E20Tv-Thermal​
  • Sensor: 7.68mm x 6.144mm
  • Image: 640px x 512px
  • Focal Length: 13mm
  • Almost like E10Tv-32-Thermal, except its Focal Length is 14mm
E20Tv​
  • Sensor: 5.64144mm x 3.1784mm
  • Image: 1920px x 1080px
  • Focal Length: 3.5
  • Same values as E10Tv
Reactions: regetskcob
GiftNexa Jaipur
