- Joined
- Feb 11, 2018
- Messages
- 161
- Reaction score
- 71
- Age
- 46
Just a quick question to see if anyone here has been using the new terrain follow feature? I eventually got it to run out on site 2 days ago. Site has substantial level differences so it was really needed.
The issue I had was around the terrain data. I had planned ahead and downloaded the maps and terrain for the area and transferred it from the desktop app to the controller by remote sync. Likewise for the flight plan as this was to be a double grid (DP only allows single grid with terrain follow so I added a second manually).
Unfortunately when I went to upload the plan to the drone out on site it complained it didnt have access to the terrain data on the server - of course, wifi was in use by the drone only! So I disconnected the drone wifi, powered up my phones hotspot, and tried redownloading a much larger area of mapping & terrain. Same problem when uploading to the drone.
After some swearing I finally found a workaround which was to connect to the hotspot & save the plan to a new file. This seemed to have forced a download of the correct terrain data, then I could connect the drone and upload the flight plan and off it went.
Have to say watching it change altitude on its own with some steep hilly terrain was rather dramatic, but it did a fantastic job, and with quite a stiff wid aloft!
Has anyone else had similar issues? I would consider some other method to make sure the controller can be online at this point as a back up, but I guess that could be tricky with android.
