Downloading Telemetry from ST10+?
Does the ST10+ controller actually store any of the telemetry data in the android memory? I would like to download some of the CSV files that were captured when there was no SD card in the ST10+ card slot.
Can you put the ST10+ in Android mode (like the ST16) and just copy the files from internal to card memory?
Thanks,
Henry
The ST10+ is definitely Android, but does require the SD card to be inserted. You don't need to remove it to download telemetry information, just plug the ST10+ into your computer and use the normal Android File Transfer utility :)
Thanks,
Henry
No, it doesn't store in the memory, that's why you need the SD card.
SemperSaint
