Dron yuneec q500 problema emisora.
Buenos dias a todos. Soy nuevo por aqui, e tenido un problema... Instale un firmware en la emisora.. y ahora tengo este problema.. os envio foto para si sabeis algo o como solicionarlo, michas gracias a todos un saludo desde españa. Raul
Translation:
Good morning, everyone. I'm new around here, and I had a problem... I installed a firmware on the station .. and now I have this problem .. I send you a picture if you know something or how to solve it, thank you all a greeting from Spain. Raul
Raul,
¿Qué controlador tienes? ¿Es el ST10 o es el ST10+?
¿Qué versión de firmware has cargado?
Raul,
Which controller do you have? Is it the ST10 or is it the ST10+?
What version of firmware have you loaded?
Tengo el controlador ST10 +. Creo que instale este firmware, te mando foto.
gracias. El primero de arriba, pero esto ya hace unos 6 meses que pasó.... SaludosScreenshot_20200403-195840.png
Translation:
I have the ST10+ controller. I think I installed this firmware, I'll send you a picture.
Thank you. The first one above, but this is about 6 months ago... Greetings
Por favor, describa el problema que tiene. También sería bueno mostrar una imagen del ST10+ con el problema en pantalla.
Please describe the problem you have. It would also be good to show a picture of the ST10+ with the problem on screen.
Instale el firmware: ST10 + Firmware Vst10 + v01b30c (Achtung: nur für ST10 +).
Ahora mando imagen del problema en pantalla.15859397092165911379997682870205.jpg1585939767943695509352851147256.jpg
You have incompatible or corrupted video drivers. The solution is in the first post of the linked thread below. However, it's all in English, and it's a bit complex. I don't know of any guides like this in any other languages.
Avete driver video incompatibili o corrotti. La soluzione è nel primo post del thread collegato qui sotto. Tuttavia, è tutto in inglese, ed è un po' complesso. Non conosco nessuna guida del genere in altre lingue.
ST10+/ST10 Un-Brick Guide
Muchas gracias, mañana lo miro en mas calma. Saludos
Thank you very much. I'll look at it more calmly tomorrow. Greetings
Muy buenas todo perfecto me acaba de funcionar muchas gracias por todo. I saludos sois unos fieras. Vamos hablando
Google Translation:
Very good, everything is perfect, it just worked, thank you very much for everything. Greetings, you are wild beasts. Let's talk
Jesster0430
