E90X camera parameters for Pix4Dreact
I am unable to process images in Pix4Dreact because the E90X camera is unsupported; however, importing the right xml dataset of parameters (listed here: https://support.pix4d.com/hc/en-us/...o-process-an-unsupported-camera-in-PIX4Dreact) should rectify the problem. Apparently I am failing to do this correctly. Can anyone help?
Problem resolved: EXIF data contains a space in the camera name but in the xml file, eliminate the space. The remaining parameters can be found in the downloadable camera parameters file with a search for E90.
Reactions: Pier2162
jonnyelectric
