Since the last update my H has had issues in its response to to yaw MN on closer examination I seem to have a problem with the yaw control on st16, in that when throttling up or down the st16 also applies yaw, it also has erratic unresponsive behaviour to the yaw control.
St16 has been calibrated.
My thinking is it is either a st16 firmware issue, though might be a dodgy left stick on the controller. Will try dropping back to the older firmware to see if that solves things.
I have contacted Yuneec
