This file was generated by using the Yuneec 502 Drone App DataPilot with analysis from PX4. I downloaded all my flights in the history of the drone via DataPilot then chose just the last one and uploaded the UGL file to this link where I got in less than two minutes an 11 page report which I've attached here. By the way it is interesting to note that despite my H+ powered back up with battery installed to download the files you do not need a battery or need to power up...when you plug in the the usb cable it receives power from the computer and a small green light comes on which is located near the battery cavity which can easily be seen blinking while downloading data using the DataPilot app. This means that even in a severe crash you should still be able to retrieve critical data from you H+.without a battery or powering up. Thanks to Steve Carr for that tip.
