Firmware version_ which one ?
Hi what firmware do i have to use to get
FCV 1.1.2
ESC 1.0.3
CAM 1.0.2 F
Can anyone help me?
Which firmware was the best in your opinion?
When you power up your Breeze it should notify you what firmware is installed and either tell you to update it or ask you to search for update on the screen. As I indicated, it depends on where you are located and weather you are using Android or IOS phone
I installed firmware V0.1.35_F.bin and I have it now
FCV 1.0.8 ESC 1.0.3 CamVer 1.0.2 F
I want to have:
FCV 1.1.2 ESC 1.0.3 CAM 1.0.2 F
Which firmware I have to use ?
I use breez only in Europe (Poland, Greece, Croatia) on Android phone
I want to have:
To get FCV 1.1.12 you have to install V0.1.47 (the latest) and then manually downgrade to V0.1.35 So you will keep the latest Flight Control Software at 1.1.12 and have the cam 1.0.2 F.
FCV can only be updatet upwards, there is no known way to revert to earlier versions of FCV. Keep this in mind, you might be unhappy with the newer version. AFAIK the newer FCV mess with the no-fly zones.
ankit09sharma20
