Gimball H Plus
Hola, no sé que las imágenes no son horizontales.
Se puede ajustar el gimball.
E
Hola, soy Jesus Luengo, estoy en España.
Soy nuevo en el foro.
Tengo un problema con el H PLUS
Las imágenes no son horizontales, ¿se puede ajustar el gimball?
Hi, I'm Jesus Luengo, I'm in Spain. I'm new in the forum. I have a problem with the H PLUS The images are not horizontal, can the gimbals be adjusted?
Hi and welcome to the forum. The gimbal has no manual adjustment, nor can you perform a gimbal calibration but; it is thought that the gimbal is calibrated by performing an Accelerometer calibration as outlined in the manual. Have you tried that?
@Jesonus Could you also post a picture to see how bad it is?
Reactions: Ty Pilot
No, lo demostraré. Es muy poco pero se nota.
Gracias.
No, I'll show you. It's very little but it shows.
Thank you.
Use the attach file to up load it here.
Are the rubber grommets on the gimble installed correctly or damaged? Sometimes they slip out during shipping,
Esperando los resultados. Asegúrese de que los ojales de goma estén bien asentados en el cardán. De nada
looking forward for the results. Make sure the rubber grommets are properly seated on the gimbal. You're welcome
nextsi
