H battery charger
I have a question on chargers. I have an h and the sc4000 charger.
Best buy sent me new battery but they sent me one for the H+.
Since the sc4000 won't charge it, what is the part number of the charger for the 5250 4s/15.2v Charger.
Or, should I just send it back and get the right battery for the H.
You might ask yuneec skins or wtfd, doomeister or a multitude of pros will be along.
If you can return the battery to BestBuy then it would be cheaper to do that.
The stock charger for the H+/H520 batteries is the SC4000-4H for the 4S 15.2V LiHV batteries (your OEM charger is the SC4000-4 sans H).
@Yuneec Skins should have new batteries in stock soon for the H480, H+/H520, and the Q500.
If you are only using the OEM charger, I would highly suggest acquiring a charger that will allow you to put your batteries in storage charge and to measure internal resistance. Most will require adapter cables for the batteries.
Reactions: Yuneec Skins
jonnyelectric
