@kia_bcn
Since I had a bad battery I decided to see if I could take it out. Yes! If you have an extra bad battery you can replace it.
open the back side, in there you will see a wire, slide that to the left using a needle nose, then take the spring out using a screwdriver, push the spring down from the top, the spring can now be taken out.
now I will attempt to replace.
