H520E arm antenna’s differences
Has anyone noticed that the h520e seems to have 2 different style antennas on the arms, one is square shaped with led inside, the other just like a cylinder style , I’ll add some pictures for reference. Perhaps later models use a different style ?
The square one broke quickly when tilted or even when packed into the inlay,
the cylindrical one is much more stable, but still a weak point.
The square ones must have been on the older model when first released and then they redesigned it with the cylindrical style would that be correct. Even the lampshade is ever so slightly different with a small bit more material for extra strength. But yes both definitely flimsy. It looks a bit like an attempt to use the same arms
Conversations
