H520E drone – update problem
Enrico, I know that, but the problem is that when I do that, it's as if I'm starting from scratch, i.e. I delete the mission and there is nothing left, but when I exit and then re-enter the mission, I have another one, and so on and so forth. Is there somewhere I can go to see all the missions and delete them (I can't see the drone when I connect it to my computer, just like when I connect the controller, but I've seen them in other places).
It seems I didn't understand your question correctly. I don't speak English and have everything translated... which leads to misunderstandings.
As far as missions are concerned, there are two different areas.
1. The drone
2. The remote control
Only one mission can be stored in the drone at a time.
Countless missions can be stored in the remote control.
There are two ways to delete all missions on the remote control.
1. Via pad mode... Android and the internal file manager
2. Via the USB port and the computer
The missions are stored in the following folder:
DataPilot / Missions
If you delete the missions stored there, they will be lost forever.
I hope that these instructions will help you succeed.
Was the H520E new or did you buy it used? My tip for you... reset the ST-16E to factory settings. Then download DataPilot version 2.2.53 from the Yuneec server and install it either via USB using your PC or via micro SD card. Then go back to "Version" and download the remaining updates where necessary. Then you will have a clean system again.
Microsoft OneDrive
I think this recommendation is the best approach. I tried the download over the air but got the issue where it would not update as a file of the same name existed , even though it was 2 different software versions . The other option is download the latest software OTA and go to settings and locate datapilot, delete it and reboot, it then lets the new update install from the sd card. Now for the downside to this at least from what I’ve seen, it gets updated but it must leave some data somewhere and it’s not a clean install like Enricos better suggestion . When u enter data pilot sometimes the video feed tile won’t appear , u still get telemetry and maps but no video feed or no tile where the video feed appears. I hope I’m explaining this correctly
Conversations
