H520E Repair Service
Where can I get my H520E repaired? Vertigo Drones appears unresponsive. Yuneec Skins is going through an unfortunate tragedy. There appears to be little to no support for Yuneec Service Centers.
Important diagnostic questions for OFDM drone/camera repair:
Did any/all camera mount dampers come out?
Did the camera mount base detach from the drone?
Other than that, most of the damage appears fairly routine and will only require parts that are the same for all the H520 sized models. Some models are not orange, but the parts are otherwise the same parts.
The obvious damage to the camera itself is repairable. If the camera ribbons are broken, it may be a bigger issue.
The broken antenna mount may be an issue because I know of no currently available replacements for the special lamp shade it uses . At least none I know of.
At least one other drone was fixed by coming up with a home made remedy that worked for that case. Not sure what will work for yours.
Unfortunately this is our problem. I've been repairing my own and selling a few I use because I can't find any support here or in the UK. There are a lot of smart people on this forum with lots of details on repairs. I have a camera gimble cover that looks like you need from a none working camera. The top and bottom shell can be found on line. I have a full set of motor arms if you have one damaged. I warn anybody purchasing from Ingenious seller on eBay that the last two orders have not been received and no communication. Pain in the rear to get eBay to return my money. Learning to work on yours is the only way to keep it flying. Good luck.
In Poland, there is a service centre in Krakow that specialises in repairing Yuneec drones and reportedly still has the last service parts for various models, which it repairs using original parts.
You can contact them at [email protected]
Reactions: h-elsner
Conversations
