Hello, new user and problem
Greetings from Birmingham Alabama USA, welcome to the forum! We look forward to hearing from you!
ok, I was able to try the new update.zip file provided in the link, I get the same errors, so it must be something I'm doing wrong?
I get the following output when doing a fastboot update (this is using the minimal adb
C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot devices
BaytrailA01BA602 fastboot
C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot update
archive does not contain 'android-info.txt'
error: update package 'update.zip' has no android-info.txt
C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot update update.zip
C:\Program Files (x86)\Minimal ADB and Fastboot>adb devices
List of devices attached
Probably not doing anything wrong. The update is just an update. It is not a full factory image complete with bootloader. You will need to send the controller to a service center that can wipe the controller clean and bootload a fresh image of the entire original firmware. You need to talk to the service centers first to ensure they have the software, firmware and training to do the bootload.
You may want to consider keeping it as a spare parts controller. It will eventually have great value in that role.
well at this point both the 'good' drone and the 'spare parts' drone are both just a lump of spare parts.
just an update, nothing really new, but I was able to capture this message on the dead ST16, this message pops up for a split second before it reboots, had to record a video in order to get this, it pops up and goes away too fast to read otherwise. I know it doesn't really help anything, but just another indication that this boot image/device is bad
EFILINUX ERROR [start_boot_logic:469] No valid target found. Fallbacking to MOS
Reactions: WTFDproject
kiravely
