Help with st16
So just got a new typhoon h, flying works, I'm having problems with the tablet side of the controller, Google play won't allow me to download any apps, any suggestions?
Don't load any. You don't want to have apps interfering with the H in flight at any point. Curious, what apps do you want to instal as there are a few that are ok to put on...in a way....?
Google Play won't work on the ST16. Indeed, it is that way so that downloaded apps not approved by Yuneec can't cause issues during a flight. You can get apps onto the ST16 by other means but it is most definitely not recommended. An exception, though, is the UAV Toolbox designed by a member of this forum called Tuna.
Use this site’s search function, the little magnifying glass at the top right of your screen to see many more posts about Google Play Store. Or you can save the effort and accept you don’t want to fuss with down loading it.
LeonorJepp
