How to aim the DSB Itelite antenna.
Hi, the "instructions" says that you should aim the antenna perpendicular to the ground. For me it seems strange... What do you think, is that ok, but it seems to be great when looking at the video:
How to aim the antenna if you fly right above yourself or much higher up? Pls advice. I use a "H".
Best from Sweden
The flat face of the antenna should be aimed at the H.
Hi, NO that's not true. Ref to both the manufactor of DBS Itelite and the video the best result comes from aiming the antenna perpendicular to the ground. I am interested in "why?" and how to point it when flying above you and high up. Did you watch the video? Can the explanation be that if you keep it perpendicular to the ground. there will be reflextion to the ground and then up to the drone?
edtechlearning
