How to calibrate the sticks of the H3
How to calibrate the st16 instrument sticks on the H3 drone (right section to 25%) and I don't know how to enter the calibration settings on this model.
I think it is the same as H Plus, ST16S:
Leave the flight mode app and confirm to get into pad mode.
Go to apps
Select FlightControlModeTest (written as FlightContralModeTest for some reason)
You will get into test environment
click Controller test
Click next to enter stick calibration screen, click on start...
Larger deviations may point to an HW problem. Maybe calibration is not enough.
How to calibrate the st16 instrument sticks on the H3 drone....
I would agree with @h-elsner. A 25% stick error is unlikely to be a calibration problem. It would be better to at least do the stick maintenance before attempting calibration.
This video by @Steve Carr shows how to remove the ST16S rear Cover:
This document provided by @DoomMeister shows the required gimbal maintenance for the very similar ST16.
Control Stick Gimbal Maintenance
The calibration should be the same as this:
Reactions: WTFDproject
Write your reply...
vct88
