HPlus crash repairs
I have a Yuneec typhoon H plus, is there no one in the usa that does repairs ?
Did i get burn buying this coptor, only had it for 3 months, bought used.
Explain what problems your experiencing or if you have damage.
I had a crash, camera detach from drone, wires showing, real sense seems to be off, copter takes a long time to connect 11 satellites, or want connect at all even on sunny day
Pictures of the damage will help. especially the "wires showing".
GPS can have a host of reasons. Did the time to connect GPS get worse AFTER the crash?
RealSense is not generally considered much of a priority. Do you have a special need for it? Damage to RealSense can be repaired or replaced, but many disconnect and remove it even if it is working properly. (Opinions may vary) Also note RealSense does not work much at first. It builds a map of the area during repeated flights through the same area. If you have not flown the same area multiple times. it is normal for RealSense to "seem off".
Reactions: h-elsner
shnippy
