Hplus h520 parts
I’m going to break 2 h520 and 2 hplus for parts . They are complete units so if there is something you can’t locate for either model I’ll have it. Not selling any complete models as I can’t ship the lipo batteries. Plenty of cameras like e90, c23 , e50 . Everything will be tested and fully functional. If you can find a better price elsewhere for parts I’ll try my best to beat it , sometimes shipping costs are more expensive than the value of the part. I can ship worldwide. Drop me a dm if you need anything 😊
Is there a different real sense for each model or just the connecting wires?
I’m 99 percent sure there is a difference in the typhoon h and h plus modules. There is no realsence to my knowledge for any other yuneec models.
One thing I’ve always noticed is a wire inside the housing of the h520. Not sure why it’s there . I think it’s for a realsence but it isn’t compatible with that model. Maybe yuneec intended to add it at some point but it never happened. Some of the early videos for the h520 showing display models had an orange realsence attached . It never came to market however as it’s probably not needed on a commercial unit
Perhaps ur right, I see this one online that says it’s for both models. Most listings say it’s for one or the other. I have 2 fitted on typhoon h and one fitted on a h plus but I’ve never put my trust in them. I always switch the obstacle avoidance off because of the ticking sound. Maybe someone can confirm if they are cross compatible, I’m a little skeptical
So the H and H pro has a twisted cable that connects the two to the real sense
On the H520 and the typhoon H plus the wires are straight and run parallel.
I’ll see if I can see if the plugs are the same. If you look on Yuneec Skin‘s website under the real sense module cables, you can see the difference.
Does this mean the module is potentially the same with just a different wire . I hope so
One end of the wire has a smaller molecule plug that plugs into the 520 board that’s the only difference between the two wires that I could see. the others end that connects to the real sense is the same in both wires. Whether there is a option to use the real sense on the 520 controller and in the system is another question.
One end of the wire has a smaller molecule plug that plugs into the 520 board that’s the only difference between the two wires that I could see. the others end that connects to the real sense is the same in both wires. Whether there is an option to use the real sense on the 520 controller and in the system is another question.
Excellent, I must try a h480 module on a hplus just out of curiosity. Just to see is the module physically compatible in size and whether it’s compatible to function. It won’t work with the h520 I’m almost certain but I’ve been wrong more that right before (at least that’s what the wife says) 😂. The software on the controller for the h520 has no realsence information as part of the packet, at least to my knowledge.
GiftNexa Jaipur
