Intel RealSense with Curve Cable Cam
Hi!
Does anyone know whether if realsense obstacle avoidance is able to avoid obstacles on a curve cable cam defined route?
I mean, will it realct to a new obstacle when it is following a defined track?
Reactions: dfogg
Yes..
When doing the ccc it's very important to know what is between points as it will fly a stright line to the next.
Thanks! Good to know. I found nothing in the manuals about CCC disabling OA. Probably just a nit but the manuals say it flies "curves" rather than straight lines between the points. In any case, Ty Pilot (Patrick), suggests running a test flight after setting up CCC to make sure everything goes according to Hoyle. If that's good then do the run and pay attention to the video or camera.
Reactions: dfogg
nestsfinder77
