jello effect on cgo3+
hi yuneec friends,
have shoot yesterday with 24frames...
and by flying to left i get a jello effect. is there a trick to fix it? props are balanced
or is it only possible in 50/60 frames to fix it?
...and can somebody help me to switch from eu version to standard? i know i have to rename the cam file ...but in end i have problems to bring all files together...
i have got a replacement cam, but it's with eu. in that case the connection breaks again with landing gear, or if i change some settings in cam
thanks for help
hi yuneec friends,
thanks for help
here HOWTO: Update E, F, J, K to Standard (A) firmware, if latest version is already installed
Reactions: eric bee
hi yuneec friends,
I think its the frame rate you need to change. 24p causes stutters on moves whatever the camera. 50p for nice smooth moves along with 50th of second shutter controlled with ND filter if need be.
Reactions: eric bee
hi yuneec friends,
thanks for help
24 frames looks odd on video playbacks. It needs film posting and be output as such to smooth out. Same with going up to 4K if you don't have proper monitor. A standard 1080i monitor looks crazy with higher resolution but in of itself is an interesting look. ND filters help minimize some problems depending on filter type with camera settings. The polar pro set for the CGO works great.
Reactions: eric bee
If you have actual jello, check and verify all 4 of the gimbal rubber isolation mounts are correctly attached to the mount.
Reactions: eric bee
@fux
thanks a lot for update the Patch to 3.01
and again i have the stable A-Firmware on copter and dropouts are history
Reactions: fux
misterfantastic
