Good question. That seems possible since the H920 and H480 units have similar width and depth. The H920 unit is much longer. Is there a source for only the H480 actuator motor?The internal construction looks is similar to the module used on the other Yuneec aircraft. I wonder if the motor is the same???
It most likely is. There were two versions they put out. An original that had a lot of parts, and a more simplified version.The internal construction looks is similar to the module used on the other Yuneec aircraft. I wonder if the motor is the same???
I think that is exactly how it works.I guess the control module could de-power the motor when the the actuator reaches full up or down and the motor current
Photos and dimensions would be helpful. I may also have issues with the very small reduction gears in the H920Plus actuator. Kind of like working on a small clock.I think that is exactly how it works.
I can post a picture of the motor with some dimensions. I think I have a motor from an actuator that has a bent screw shaft.
