I guess I should have been more specific. I fly domestic USA. Anyone have experience there with over 100 wh?
The information below is from Traveling With LiPo Batteries and Your Drone - Dronethusiast
Quantities
The quantity permitted is based on watt-hours (Wh). Wh establishes the lithium content by multiplying voltage with the ampere-hours (Ah). For example, 14.40V x 5Ah battery = 72Wh.
The current IATA dangerous goods regulations and your rights as passenger to carry the LiPos with you in carry-on luggage but not in your checked luggage. There are 3 classes of LiPo batteries. Below 100Wh there are no quantity restrictions as to the amount of batteries you can carry. Between 100Wh and 160Wh you are limited to two battery packs total per passenger. Above 160Wh you are not permitted to carry the packs as carry-on.
Avoiding short circuit
As another safety precaution, though this might not be mandatory according to flight safety regulations is to avoid short circuiting the batteries thus increasing the chance of fire hazard. This is fairly simple, all you need to do is to place each battery into an individual plastic bag. This will come in handy when labeling also, see below. You can also shrink wrap the battery connectors with saran wrap. This process only takes a few seconds and reduces the possibility of electrical arcing and moisture getting to the battery connectors.
Labeling
It also maximizes your chance of your carry-on batteries not being declined by safety personnel if you stick a “Lithium Ion/Polymer Rechargeable Batteries Inside” label on each plastic bag. You can order a set of 500 pieces (will last you quite some time) via Amazon for about $26. Of course it should probably be ok for you to print your own labels, but these professional looking labels will suggest to the TSA agent that you know what you are doing.
Lithium Ion/Polymer Rechargeable Batteries Inside Label
No Old Batteries
Old batteries with lots of cycles on them are more dangerous to transport because the advancement of chemical reactions inside them. Never transport any batteries showing the signs of swelling or ones that are punctured in any way. Also do not transport batteries that should be retired soon. As a general rule, when your battery no longer holds more than 80% of its original capacity, it’s time to retire your pack and certainly if there is excessive puffing.
LiPo Bags
Placing your batteries in
LiPo safe bags is an absolute necessity, if you don’t have them, do not even attempt to carry them on board an aircraft. This is also for your safety. Of course you do not need to have a separate LiPo safe bag for each battery as you have also placed them in separate plastic bags as suggested above. But depending on the number and size of your batteries, be sure to have a bag with enough space for them all, or use multiple bags. This one is a good option, but you can buy larger ones also:
