lights
Well I made a brace between the landing legs of brass Rod 3.5 mm diameter and soldered a bent hook out to the front about 30mm and drilled a hole in each leg to take the bent ends and now you have a delivery system for bait to the fish without any danger of getting caught up in the frame or legs . It is simple , when I get good at videos I will do a a short one and put it on the forum incase others would like to try it, you need a lot of line to get out to the big ones. To date I have a perfect strike rate 8 trips out and 8 fish. Thanks for asking and I guess the seaweed on the bottom can be classed as grass so in technical terms I am on the top side of it. Thanks for the inquiry Rubicon and will send photos of the setup . Johnno Hennessy
malikaya97
