Live stream....?
Brisbane Australia
Who has done it?
I need to get this happening yesterday (loose a sale if I can't get this to work.... Since DGI can do it apparently)
I am happy with external HDMI converters or something but need this to work.
What about pumping out from the ST-16’s HDMI port using an external video transmitter to one or more monitors with video receivers? Sure, it would be degraded to 720 and have some latency but it would work.
If Yuneec is at all serious about targeting the commercial market this area is something they should be devoting some resources. If you can’t live stream to multiple receivers you will be a decade behind those that do. SAR, surveillance, and fire suppression absolutely require it. Inspection benefits greatly from it.
No it has to go to Facebook.
As the government needs to transmit back to its head quarters from out a boat which is of an island which is off the coast by a few hundred kms
Good luck with that, although it could be done through employment of series of transmission and signal conversion devices. It would certainly not be a "live stream" by the time it reached FB. I don't comprehend why a government would stream anything to a Facebook account. Governments usually don't like anything going out they don't control or censor. You've entered an area typically utilized by broadcast media using satellite or digital transmissions for wide distribution productions, or by governments normally employing encrypted digital data and secure servers. Yuneec has, to my knowledge, not yet embraced any technology that would permit what you appear to need.
External field monitor running on android with HDMI in. Load Facebook app onto the monitor and WiFi the monitor to your mobile phone hotspot for internet connection or usb to phone should work Haydn.
Got a link to one of the monitors?
peterniven
