Earlier CGo3 camera firmware does not work well with the ST16 onscreen display. Lots of breakup and artifacts. Upgrading to the latest CGo3 firmware will clear up almost all artifacts.
But there are also good news:
With channel settings you can do a lot more for the Q500. I got a model from a very experienced friend that gives us back the Stability flight mode (Blue mode) from the 350QX or Chroma for the Q500. RTH is moved to the landing gear switch.
See ST16 als RC - Stability Mode - Drohnen-Forum.de - Quadrocopter, Multicopter und FPV
Model can be downloaded at #10. Use it on your own risk (as usual). But still the CGO3PRO (which has more possibilities for Cam settings compared to the CGO3 model) cannot be used. I think there is no way to overcome the firmware build in compatibility checks.
Remark: Blus mode (or Stability) means, you have the same behaviour like without GPS (More speed, more rate, more resposibility on the sticks) but you keep RTH and the position stability per GPS will take part after a delay of 1-2s if you let the sticks alone. If you take back the control via stick movement it will cancel GPS support and drift with the wind and react fast and direct to the sticks.
From my point of view the best flight mode Yuneec ever made. Of course not good for smooth videos, but good for fun.
Is the ST16/Q500/CGO3 video downlink fix to update the CGO3 with the latest Q500/CGO3 firmware;
cgo3gb_2.4.00_A_firmware.bin
or to update the CGO3 with the latest H/CGO3+ firmware:
cgo3+gb_3.2.34_LC2_A_firmware_30234.bin
If I get the ST16 to play nice with the Q500/CGO3 will I be able to go back to using the ST10?
Thanks,
RG
The cgo3gb_2.4.00_A_firmware.bin will provide pretty decent onscreen video. I was never able to get a CGo3 to accept the CGo3+ firmware.
The CG03+ video does not work well at all with an ST10. If you change the CG03 processor to a CG03+ processer, and I suspect if you find a way to update CGo3 Firmware to CGo3+ firmware, you will find the CGo3+ video displayed on an ST10 is not even close to being useable.
This is about the limit of what I know, and going beyond is guess work. My current “guess” is that the “Model” profile MAY have something in it that will allow the “CGo3 Pro” features when using a CGo3 camera on an ST16/Q500 combination. Hence, here is my question;
Does anyone know of a way to copy a Q500 “Model” from an ST10+, and load it onto an ST16?
You can download the ST16 firmware from the Yuneec website. The problem you will have is getting past the password protection on the file.
Don’t hold your breath. If they continue, it will be in Asia and the EU. I’m pretty sure we have gotten the mid finger salute.Hi Doom
Do you think will
Yuneec will make a new
Showing of sorts.
I Love my TH 480
Good question! Since they are actually different firmware, my guess would be that you could swap back and forth.Is it possible to change US firmware to EU? If you bought a brand new ST16 from USA. I thought I read here you might be able to do once?
