low avionics power 4.70 volt
putere avionică redusă 4,70 volți yuneec H plus taifun apare pe ecranul meu, ce pot face?
(...)Am încercat aceeași semnalizare cu 2 baterii încărcate
Google Translate:
low power 4.70 volts yuneec H plus typhoon appears on my screen, what can I do?
(...) I tried the same signaling with 2 charged batteries
If you are seeing this only when first starting the aircraft it is a normal warning message. It appears as a MavLink message before the aircraft is fully initialized.
If you are seeing this after the aircraft has been powered up for a minute or more, then there may be some serious issues with the power distribution on the Mainboard or with the Flight Control module itself.
Yeah, when I first got my Plus we were baffled, but as Doom says - this is normal to see when starting up but if you see this after motor start - there could be an issue.
Many people mistakenly believe that there is nothing complicated about electrical work. A qualified electrician knows all the intricacies of his business. In a relatively short time, he can determine the causes of the problems and choose the optimal solution to the situation in question. In addition, an experienced specialist from gordonpowers.com.au knows about the necessity and methods of safety. It is essential to understand that all activities that are somehow connected with electricity are dangerous to human life, especially if the mains voltage is not less than 220 volts.
Depends on the job at hand. Some are easy and some are difficult. I am a retired electrician/electronics technician.
snoopy68
