Mantis g pilot app
Dear all,
My brother gave me a mantis g drone but I am unable to find the pilot app...
Do you know how I can get the app to pilot my drone?
Thank you
Thanks Joseph.
Unfortunatly i am unable to install the app.
I think my android version is not accepting to install this app.
Is there a workaround?
Have you gone into Android Settings and allowed it to install apps that are not in the Playstore?
The Yuneec Pilot app was designed for an earlier version of Android (v5.0) and does not function well with newer versions beyond Android v7.0. You can try running an app that emulates earlier versions of Android to allow your present phone to work with Yuneec Pilot.
Another option is to try using an older iOS phone that runs iOS 10 or greater. The Yuneec Pilot app actually a bit better on iPhone/iPad.
I have used both iOS and Android versions of the app.
If you opt for an older compatible phone of either type of OS, you do not need to have cellular service. It is actually better if cellular is not active since the phone is being used as part of the Remote Control for the aircraft.
Reactions: Enrico Jorysch
Thank for your reply.
I can have a iPhone from à friend.
Do you lnow where i can found the app for iPhone to try ?
Thanks
Thanks
When you get the iPhone, open "APP Store", search for "Yuneec Pilot", and install it.
I just did this on an older iPhone SE with IOS 18.1.1., and it seems to have installed normally. It also worked on my Grandson's iPhone XR IOS 18.0.1
Hello,
Yuneec Pilot app is no longer available on apple App Store. When I click the Yuneec icon on my iPhone it tells me:
Unable to Install "Yuneec Pilot" The app is no longer available in the App Store.
Any suggestion on how to resolve this would be greatly appreciated.
BTW: This is from the US App Store.
Thanks,
Dutch.
Until the Yuneec Pilot app is restored to the App Store you are left with only one option. If you made a backup of your phone to the iTunes app on your PC or Mac when the Yuneec Pilot app was on your phone, then you may be able to recover it from the backup.
If you are not familiar with how to do this contact Apple Support.
The Yuneec Pilot App for the Mantis Q and G is still available in the Swiss AppStore.
If it is no longer available in your country, simply change the country setting on your iPhone.
Reactions: DoomMeister
The following Yuneec apps are once again available in the US App Store:
Breeze Cam
CGO (same cameras as CGO3 for Android)
CGO4
Yuneec Pilot
Breeze Cam
CGO4
Yuneec Pilot
Hello can I ask is there a way for me to get the app in the uk I have just bought the breeze 4k with no controller and I cant get the app and can you advise on what is the best android phone or tablet I can use I have found files but these are using bluestacks app and they wont install on my phone
Thank you in advance
Steve
Steve
This link leads to both the OEM and some clone versions of Android Apps. @DoomMeister will have better information on which phones work, but "old, really old" is a general idea.
Steve
You mention BlueStacks so it sounds like you are attempting to run an Android emulator on an iPhone or iPad. You can download the iOS version of Breeze Cam from the App Store ‎Breeze Cam
Newer Android phones are challenging to get this older app to run properly. They always think they should be connected to the internet. Best practice is to put the phone in Airplane mode then enable only WiFi to connect to the Breeze. The apk files have to be side loaded since they are not hosted on the Play Store any longer. Many drone manufacturers do this because of the hoops they have to go through to be hosted on the Play Store. It is not financially feasible for outdated apps.
Dear all,
Thank you
I wasn't able to reinstall on my I phone until yesterday. It showed back up on the App Store for IOS!
beanut
