Mantis Q Maintenance Guide
DoomMeister
Moderator/Tech Junkie
Staff member
Premium Pilot
Genesee, MI USA
This is a document that is still a work in progress, but contains the information to remove and replace most components of the Mantis Q. I will add more information as it gets developed. Since this is the bulk of the information I decided to publish it.
18 Mar 2023 - v1.1 added motor arm and propeller replacement
19 Mar 2023 - v1.2 added camera servo replacement
Updated to v1.1 on 18 Mar 2023
Reactions: WTFDproject
Thanks Chris, but also get a lot of good things from @h-elsner, @WTFDproject, @Steve Carr, and now @flashcoder.
As a group this is one of the most helpful and informative groups for Yuneec drones. Although the latest ones are well outside our prosumer budget range, so very little guidance here.
Buen trabajo y documento. Muchas gracias @DoomMeister
Good work and document. Thanks a lot
Thank you for your compliment.
I know you own the Mantis G which is a much better drone than the Mantis Q. I plan to create a similar document for the Mantis G in a couple of months. It is similar, but has no interchangeable parts with the Mantis Q other than propellers and batteries.
v1.2 posted
I had never seen a Mantis until yesterday. Today I used the guidance provided by @DoomMeister to disassemble it. I had no problems and did no damage getting it apart. (That's an especially good thing, since the Mantis belongs to @Steve Carr. :) )
Without the instructions I would not have had a chance.
Reactions: DoomMeister
cpassenheim
