Map your flights on Google Earth
RG...
I deleted all my KML and KMZ files created by your site and started over
I can get to 0:50 on your video, but when I click on Map then the KML icon I get a "Save As" window.
I do not get the Google window that you show at 0:50
I saved the KML file but can not get any further...
Thank You for Your Patience.
Once you have saved the KML file on your hard drive, right-click it and select "open with", then find Google Earth and select it.
You can also do it with another method which consists in opening first GE, then from GE file's menu select "Open", browse to where the KML files are located and select one of them.
Once the KML file is loaded in GE, make sure the lateral bar is displayed (click this button Capture du 2017-07-24 16-57-50.png), then move the upper left corner slider far to the left, then from the lateral bar unfold (plus button) "Flight-Path", "Telemetry_xxxxxx.csv", and select "Typhoon H", then click the "Launch tour" button Capture du 2017-07-24 17-02-44.png
Ok..
Still can not get it to work
I can get the to the blue flight path, but no further.
" then from the lateral bar unfold (plus button) "Flight-Path", "Telemetry_xxxxxx.csv", and select "Typhoon H", then click the "Launch tour" button "
Non of this opens.
I'll save all my saved places and then download and re install GE tonight.
Thanks for trying to help !
Ok..
Non of this opens.
Are you using a KML file from WebFlightPath.com ?
Rural-Geek
Thank You ! Thanks for the Photo Instructions !
You are a SAINT !
My Problem was that I did not understand your term "Unfold"
Once I saw the red arrows I had a "AH HAH" moment.
It worked perfectly !
Add the Photo Instructions to your FAQ Section !
I hope this helped others as well !
Thanks again for taking the time to explain everything !
Atomic !
OK, great !
Sorry for my English, I'm french, so I may sometimes use the bad words !
rsaroha
