New typhoon H plus
Indiana
Up Graded to typhoon H plus .having problems with the camera. Flew around about 15 minutes on a battery no problem , camera worked fine.secount flight booted up drone and camera started buzzing and moving around on it's own buzzing.,green light on camera working,monitor ok, any suggestions would be appreciated .
Remove and reinstall the camera. Turn on the Plus on a perfectly level surface and don't move it until it is fully booted.
Have you looked at the firmware version yet?
Where do you stand with the camera issue?
No change in camera,could it be the wiring harness, I can visually see a wire in the battery compartment up by the studs that conect too the battery but it doesn't seem to be pinched .
Not likely a problem with the wiring.
The issue might repair itself if you downgrade the firmware on the ST16 and then reinstall it. There is a thread on the forum that explains how to do that.
Thanx Steve, I will look in to that. Not vary good at this computer stuff though.
I can help walk you through the steps. But it will be easier if we are both online at the same time.
Unpicked
