- Joined
- Apr 24, 2019
- Messages
- 18
- Reaction score
- 1
- Age
- 55
My camera says no network connection when hooked up to the handheld, and does not connect when hooked up to the drone. Anyone know of a fix?
There is no light. I assume it is because it is "not connected" according to the drone.Also, look at the small light on the camera ball to the upper left of the camera lens. What colors, patterns is it flashing?
No indication of having any kind of power. No stabilization or lights of any kind.Nope. Sounds like there is no power to the camera section. Does the gimbal itself have power and lights on the gimbal board? Or maybe even stabilize?
I bought this drone off Ebay. It was sold as is with no history of why it did not work. The drone I bought worked perfect after I updated the firmware, but the camera never connected. I took a camera from another q500 and attached it. It paired and worked perfectly. I also tried hooking the defective camera to a different q500 with the same results, no connection. The drone has no indication of ever having been flown, let alone crashed. I truly believe this drone was a return item and had never been flown. Every piece in the box appeared to be brand new, even the camera that doesn't work.We need to understand the history of the camera. Mainly, have the three black wires that run from the top hotshoe connector to the gimbal board ever been pulled loose, or are they pulled loose now?
I had a power problem to one of my drones a while back... thought it was the camera but ended up to be the tiny circuit card right inside the drone itself that the pigtail plugs in to...My camera says no network connection when hooked up to the handheld, and does not connect when hooked up to the drone. Anyone know of a fix?
