Please Help st10_plus_b29.bin Yuneec ST10+ firmware Q500+
Florida
I really need a copy of the st10_plus_b29.bin Yuneec ST10+ firmware Q500+ for my transmitter... It has the wrong BIN file and I can't find it anywhere.
I am turning to everyone here to find a copy
Doug
It has been a long time. Memory suffers. I may be confusing firmware and models. But I do not recall a "b29" version for ST10+. There was an ST10 version "st10_tx_b29.bin".
There are a couple of versions available for ST10+ with higher revision numbers.
I remember very clearly the blank-screen "bricks" that were created by installing ST10+ firmware on ST10 controllers. The screens are not compatible. Installing ST10+ firmware on an ST10 left a blank screen that was extremely hard to recover. I am not even sure the recovery firmware and guidance is still available and/or compatible with current operating environments.
Are you absolutely certain you have an ST10+ and not the original ST10?
This link is to some instructions that avoid some of the difficulties of the factory instructions. The document also contains a link to ST10+ files.
"ST10+ Firmware Update"
Reactions: DoomMeister
sabeelashabir
