Unbrick Yuneec camera using AmbaUSB tool
h-elsner
Premium Pilot
Bavaria / Germany
Website
h-elsner.mooo.com
I'm trying to unbrick a CGO-ET from H520. The camera stuck in initialization, front LED remain white. The WiFi module which is often the reason for this behavior works in other cameras. It looks like the main board with the Ambarella chip has some problems. @Enrico Jorysch told me that there is a tool for this processor: AmbaUSB.
I found this tool here: http://pc.cd/iap7
Also I got the settings for some Yuneec cameras:
CGO3+, CGO-ET (H480), CGO-ET (H520) and possibly E50 have the same mainboard CGO3+_MB_V2.1.
Finally I got connection to the camera but a FW update was not possible. It flashes some parts but the firmware.bin file was not taken, it leads to timeout.
It looks like the tool don't like *.bin files and requests *.elf files. I found some .elf files for Yuneec cameras but none for E50, CGO3+ or CGO-ET.
Question: Has someone some ELF files with firmware for the CGOxx camera family? An ELF file contains the bin file and some more information for the FW.
I have a CHO4 camera, which stops on the middle of the startup sequence. The Android CGO4 says that something should be uploaded to the camera, but after that the problem still persists.
Is the CGO4 in the same line, which can be maintained with the discussed tool?
Thank you very much. This is a good hint. In a first step I could create an ELF file from CGO3+ FW. Hopefully it will be accepted.
The result is as following:
Code:
ELF Header:
  Magic:   7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
  Class:                             ELF32
  Data:                              2's complement, little endian
  Version:                           1 (current)
  OS/ABI:                            UNIX - System V
  ABI Version:                       0
  Type:                              REL (Relocatable file)
  Machine:                           None
  Version:                           0x1
  Entry point address:               0x0
  Start of program headers:          0 (bytes into file)
  Start of section headers:          57864524 (bytes into file)
  Flags:                             0x0
  Size of this header:               52 (bytes)
  Size of program headers:           0 (bytes)
  Number of program headers:         0
  Size of section headers:           40 (bytes)
  Number of section headers:         5
  Section header string table index: 4
Section Headers:
  [Nr] Name              Type            Addr     Off    Size   ES Flg Lk Inf Al
  [ 0]                   NULL            00000000 000000 000000 00      0   0  0
  [ 1] .data             PROGBITS        00000000 000034 372f014 00  WA  0   0  1
  [ 2] .symtab           SYMTAB          00000000 372f048 000040 10      3   1  4
  [ 3] .strtab           STRTAB          00000000 372f088 0000a0 00      0   0  1
  [ 4] .shstrtab         STRTAB          00000000 372f128 000021 00      0   0  1
Key to Flags:
  W (write), A (alloc), X (execute), M (merge), S (strings), I (info),
  L (link order), O (extra OS processing required), G (group), T (TLS),
  C (compressed), x (unknown), o (OS specific), E (exclude),
  D (mbind), p (processor specific)
There are no section groups in this file.
There are no program headers in this file.
There is no dynamic section in this file.
There are no relocations in this file.
The decoding of unwind sections for machine type None is not currently supported.
Symbol table '.symtab' contains 4 entries:
   Num:    Value  Size Type    Bind   Vis      Ndx Name
     0: 00000000     0 NOTYPE  LOCAL  DEFAULT  UND
     1: 00000000     0 NOTYPE  GLOBAL DEFAULT    1 _binary_cgo3_gb_[...]
     2: 0372f014     0 NOTYPE  GLOBAL DEFAULT    1 _binary_cgo3_gb_[...]
     3: 0372f014     0 NOTYPE  GLOBAL DEFAULT  ABS _binary_cgo3_gb_[...]
No version information found in this file.
Code:
ELF Header:
  Class:                             ELF32
  ABI Version:                       0
  Machine:                           None
  Version:                           0x1
  Flags:                             0x0
Section Headers:
Key to Flags:
I'm curious to see what happens, so I'll be reading along
cpassenheim
