Problem with video feed
Hello i just bought a Yuneec Mantis Q and found the pilot apk in internet.
I can control the drone take photos and record videos but cant see the live feed.
Any suggestions?
@DoomMeister is the best source for Mantis Q. I assume he will need at least the brand and model of your phone/pad, the operating system and the operating system revision number. The name and version of the APK you found may also be helpful.
Thanks my friend i just send him a direct message🙏
My response is in DM.
Advice for anyone using a Mantis Q or Mantis G is to get an older iPhone that uses iOS 9 or above to avoid the video feed issue.
Older Android phones also work from Android v5 to v7. The video feed issue started cropping up in Android v8.
Reactions: WTFDproject
Thank you so much for the help🙏
After You bind the phone to the drone wifi, You also need to bind the controller to drone's wifi from within the Pilot app - in the controller setup section. Video feed works fine with both Android 12 tablet, and Android 15 phone with my drone
Reactions: DoomMeister
Thanks for you input on this Eric!
Could you check to see what firmware version you have for your Mantis and Controller as well as version of Yuneec Pilot you are runnng?
Yuneec Pilot app ver. 2.0.2 (when upgraded from ver 1.x, videofeed was lost, rebinding RC in app setup fixed problem for me)
Mantiz 1.1.7
RC 1.0.0.1
GiftNexa Jaipur
