Awesome! This will put a major star on the benefit of the H520E RTK over the Phantom RTK! We've been waiting on this long before the E models were released.
E20Tvx
E20Tvx
Yes indeed is it a great news. Having said so one needs to be aware that E20Tvx dose not come from FLIR.Awesome! This will put a major star on the benefit of the H520E RTK over the Phantom RTK! We've been waiting on this long before the E models were released.
E20Tvx
There's no doubt in that. The problem with allot of these solutions is that they are not scalable and the Yuneec drones are as close to that configuration as anything I have seen that doesn't cost $30k+. The Matrice 300RTK with L1/P1 package is about $35k but they are in the same position with the L1 vs higher-end lidar sensors. We are not a survey company nor a full time thermography inspection outfit so the 2nd Tier sensors are plenty for us and still provide functionality that we currently don't have.Yes indeed is it a great news. Having said so one needs to be aware that E20Tvx dose not come from FLIR.
I have limited kowledge about thermal imaging but talked to people who do solar panels and said FLIR had some advantages with respect to processing datasets.
Regarding the lifting power I must say that the 2.5 kg MTOM that was mentioned on the EU page for the H520 a while ago does apparently bring the power supply specs and built to its limit.The H520E definitely has enough lifting power so maybe someone will figure out how to mount a lidar sensor...
E90X as well. H520E Battery ResilienceE30Z camera that could cause problems with the battery contacts due to higher amp currents?
This happened to us as well with the H520 v1. Those batteries were really bad about swelling. I have not noticed anything yet on the H520E RTK.tried to remove the battery it was stuck inside the frame structure. So I moved the battery a bit back and forth and eventually I was able to remove it.
