the only issue is it does have a separate processor inside, even with the switch off the module still turns on but does not comunicateI don't have the T-H Pro, but if you go into System Settings and tap on the "Other Settings" button, you will see an option to check if you have Real Sense installed. I am only guessing that if you uncheck that box, that may turn off the Real Sense. I'm also assuming this would be to save battery power, right? If I am right, that would save having to rig a switch to do the same thing. You might also contact Yuneec and ask the question.
Why not just flick the obs avoid switch? or does it still consume power that way?I don't have the T-H Pro, but if you go into System Settings and tap on the "Other Settings" button, you will see an option to check if you have Real Sense installed. I am only guessing that if you uncheck that box, that may turn off the Real Sense. I'm also assuming this would be to save battery power, right? If I am right, that would save having to rig a switch to do the same thing. You might also contact Yuneec and ask the question.
