REALSENSE
Hello fellow TH Pro owners..........I may have an issue with my TH PRO but would like to confirm to see if you see the same thing I see. Can you guys check to see if the scale on your ST 16 changes form 1.3M to 2.0M all in RED BARS with a yellow bar on the ends......... why do I see the distance changing when the drone is just sitting on a table? Please confirm if you see the same as I do...........
Yes, that's the distance bar of the IPS module, which has a sensor pointing down for improved altitude hold.
I thought the bars were for OA to tell you how close you are to an object. The bars will change colors and start to beep faster and faster as you get closer to an object.
Mcgyver
