Reset camera C23
France
Yuneec Europe replied to me by email about camera vibrations that appeared after the update.
" If you have the vibration on your camera, we nearly need it inside the service center to clear this.
You may try to reset your camera, but it is only a very small chance that this will help."
here is the procedure to reset if you are interested
Reactions: Ty Pilot
So, I have the micro-vibration issue .. will try the reset above …
So, it did not work.
I pressed the reset above without the ST16 on. Did not resolve.
Then, turned on the ST16 and pressed the reset.
The landing gear retracted up suddenly and will not deploy back down.
Now, my landing gear retracting and are stuck in the up position, and I have the gimbal vibrations.
Note : the gimbal is very warm.
Exchanging to BestBuy.
This vibration you are experiencing. Does it occur when the camera is horizontal and goes away when it reaches about a 30° down angle or greater?
Had the same broblem. Kav serices. Went back to original firmware on the gimbal only. This stopped it. They ssid there jas been several updates to fix it but they do not work .
jonnyelectric
