rtk first flight
first 6 flights with the rtk went well. flights were 2 sets of 3 back to back. with e30zx. soi far no issues cropped up. waiting on a day to do all six flight batteries back to back. flight times are better than expected avg 20 to just shy of 24 min. I have to keep a eye on the connector head temps are not burning but warmer than the batteries from the h520e running first gen h520 and h480 flight batteries.
les 6 premiers vols avec le rtk se sont bien passés. les vols étaient 2 séries de 3 dos à dos. avec e30zx. jusqu'à présent, aucun problème n'a surgi. attendre un jour pour faire les six batteries de vol dos à dos. les temps de vol sont meilleurs que prévu en moyenne de 20 à un peu moins de 24 min. Je dois garder un œil sur les températures de la tête du connecteur qui ne brûlent pas mais qui sont plus chaudes que les batteries du h520e fonctionnant avec des batteries de vol de première génération h520 et h480.
A quoi sert rtk ?
Je sais pas.
What is the purpose of rtk?
I don't know.
RTK is used in mapping to provide a reference with surveying. A web search will provide a wealth of information on the subject.
Reactions: greg74
RTK enhances the GPS accuracy of the drone, typically to within a few centimeters. It uses a base station as a fixed known point and corrects the GPS readings on the drone accordingly. This is very useful in the mapping and photogrammetry world. The more accurate your drone's known/relative position, the more accurate the survey from photogrammetry is. Photogrammetry usually has a fudging factor that it allows the drone's position to be adjusted to meet the estimated triangulation; however, with RTK equipped you can tell the photogrammetry software to greatly reduce that fudge factor (typically from 3 meters down to 5ish centimeters) this limits the photogrammetry software from coming up with large amounts of erroneous data.
RTK améliore la précision GPS du drone, généralement à quelques centimètres près. Il utilise une station de base comme point connu fixe et corrige les lectures GPS sur le drone en conséquence. Ceci est très utile dans le monde de la cartographie et de la photogrammétrie. Plus la position connue/relative de votre drone est précise, plus le relevé par photogrammétrie est précis. La photogrammétrie a généralement un facteur de flou qui permet d'ajuster la position du drone pour répondre à la triangulation estimée ; Cependant, avec RTK équipé, vous pouvez dire au logiciel de photogrammétrie de réduire considérablement ce facteur de flou (généralement de 3 mètres à 5 centimètres), ce qui empêche le logiciel de photogrammétrie de générer de grandes quantités de données erronées.
bonjour....merci pour ces info sur le rtk.........
no sim card needed. has a built in wifi. connect to that and add the info into the st16e for the ntrip. for the operation manual register with robodot to gain access to it.
got the h520e rtk backup in the air didi seven back to back flights non rtk mode. set the speed to max 31 mph and now can get total distance in air up to 51k feet from 35k feet. and about 20 min or a bit more per h520e oem battery and gifi 8000mah the h3 oems 19 to 19.5 min with lower distance of 45k ft of total distance traveled at 31 mph. flights were flown in laps. not out and back just yet.
shamrock@78
