So does anyone know the LOGIN Information for the C23???
Central Florida
So, when you plug the camera in on a computer it comes up as a USB to Serial interface so I figured, what the ****, lets see if I can Telnet into it.. Sure enough I can. Need login information though. May have to throw up a serial capture devices and see what is used for login when it STS16 does updates to the camera via USB.
Anyone else try this out?
And the default PW 1234567890 does not work?
This is a user name and password login, not just a password. This isnt over wifi, completely different
It's probably an access port for Yuneec authorized techs... I have seen references for instance, to a calibration of the gimbal, that can only be performed by a Yuneec authorized technician.
If some curious hacker could develop a way to tweak the gimbal PID's, I would like to tune the pan with a lower proportional and a higher derivative.
Then I could make the yaw following smoother.
Reactions: record.play.rewind
The controller that needs to be addressed via curve/expo.
gbare
