ST-16 Hardware (Input) Error
KY
Hi Everyone,
Except for the sporadic compass errors, I haven't had any problems with my H but I just noticed this on my ST-16 and it concerns me. Red usually means bad. Can someone explain if I have a problem and what I can do to fix/clear it. I know the J1 is for the throttle stick. Thank you!
I could be wrong, but I think that just is highlighting that J1 and B1 are mixed for Thr. If you touch to select Ail, Rud, etc they will be highlighted red also. Mine looks the same.
Dylan
Thanks, Dylan. I can see that now when I look at the properties of each channel. For example the throttle and on/off switch. I just never bothered to look at each channel.
Tom
The Channel Settings menu can be a dangerous playground. It's only intended to be used by very experienced pilots who understand precisely what they are doing.
If you need to check switches, sliders and sticks use Hardware Monitor. It's safe and there is no danger of changing anything.
Understood. I hadn't been in that menu before and once I noticed that red box I was concerned about some error. I've had good success with my H in the last year. I wouldn't want to mess anything up now. Thanks, Steve.
Tom
Tom
Glad the H has been a good machine for you. The picture you posted shows Channel one to be normal so no worries.
daps20
