St-16+ just died while installing update
the St 16 just completely turned off.... so I thought it might be a charging issue, placed on charge for 5 hours using provided cable and iPad usb charger plug...it turns on no fan then screen goes black and stays there... anyone know a reset( yes I tried removing the battery for several mins then reinstalling).
You are not the first, the possible solution is published by Kev in the thread of the last update. You're not the first one that's happened to him, and so far everyone's been able to fix it. Run through this thread and see if it works for you.
1.4.1 Firmware Now LIve!!!
Reactions: Kev Waite
I rembemer reading that and totally wasn’t able to find it when I was looking for it.... thank you so much. The ST 16 has rebooted Thank you for all your help....
Abwms
