ST16 battery not charging
DAG HEREN DRONE PILOT UIT BELGIE VLIEG MET YUNEEC TYPHOON H PRO HET PROBLEEM IS. DE ST16 BATERIJ LAAD NIET OP IN ST16 OP. HET BATERIJ IKOONTJE VERSCHIJNT EEN SLEUTELTJE WAT IS HET PROBLEEM .WIE KAN MIJ HELPEN DANK BIJ VOORBAAT GERARD..OOSTENDE
HELLO GENTLEMEN, DRONE PILOT FROM BELGIUM, FLYING WITH A YUNEEC TYPHOON H PRO. THE PROBLEM IS: THE ST16 BATTERY DOES NOT CHARGE IN THE ST16. A KEY APPEARS ON THE BATTERY ICON. WHAT IS THE PROBLEM? WHO CAN HELP ME? THANKS IN ADVANCE, GERARD. OOSTENDE
Translated (according to Apple) HELLO MEN'S DRONE PILOT FROM BELGIUM FLY WITH YUNEEC TYPHOON H PRO THE PROBLEM IS. THE ST16 BATTERY DOES NOT CHARGE IN ST16. THE BATTERY ICON APPEARS A KEY WHAT IS THE PROBLEM. WHO CAN HELP ME THANKS IN ADVANCE GERARD.. OSTEND
My notes: This could probably be a separate thread.
-Do you have an external charger to try charging the battery?
-Is this the only battery for the ST16? If not, is this the issue with the other battery?
-Did the battery go through a deep discharge or exposure to heat?
Mijn notities: Dit zou waarschijnlijk een aparte discussie kunnen zijn.
-Heb je een externe oplader om te proberen de batterij op te laden?
-Is dit de enige batterij voor de ST16? Zo niet, doet het probleem zich ook voor bij de andere batterij?
-Is de batterij diep ontladen geweest of blootgesteld aan hitte?
Measure the voltage of the battery with it disconnected from the ST16. If it is below 3.3VDC it may not charge while in the ST16 because the voltage is too low.
You can charge it using a charger designed to charge multiple battery types using an adapter cable to connect to the EC2 connector of the battery.
There is a possibility that there is a problem with the charging circuit on the ST16 or the USB port. See this post St16 battery dead? and those posted after it.
HALLO HEREN, IK BEN EEN DRONEPILOT UIT BELGIË EN VLIEG MET EEN YUNEEC TYPHOON H PRO. HET PROBLEEM IS: DE ST16-ACCU LAADT NIET OP. ER VERSCHIJNT EEN SLEUTEL OP HET ACCU-PICTOGRAM. WAT IS HET PROBLEEM? WIE KAN ME HELPEN? ALVAST BEDANKT, GERARD. OOSTENDE
Conversations
