ST16 commands have been reversed??? Typhoon H
Not sure what happened but the left and right stick controls are reversed. To take off for example, it is now done with the right stick instead of the left. Very dangerous so I will not fly until I can reverse it... HELP??
System Settings > Mode select > MODE2.
If this dosn't help, create a new model from scratch, Type= Typhoon H and bind the drone and the camera to this new model.
Ok....now I am trying to "re-bind" the camera, and it requires a password..which I do not have.... Any thoughts?? I switched to mode 2 and was hopeful...but while powering up, the st16 was stuck trying to connect to camera, so I was unable to proceed.
The camera is a new issue, as I have flown a month ago with no problems.... So
The password is 1234567890
Reactions: Tom Slager
Thanks all!!! I was back in the air tonight!!!!!
Tom,
Do you have the Typhoon H with the CGO3+ camera or the Typhoon H Plus with the C23 camera?
Your post reads like Typhoon H, but it is posted in the H Plus sub-forum. I need to verify so the post is in the correct sub-forum.
Thanks.
kiravely
