ST16S Update
New York
When I was doing an update to the firmware today my ST16S will no longer boot up. The last update was for the transmitter. It started the update then shut down. Controller will not re-boot. Is there a way to do a master reset or any other ideas that may help?
Colleagues in your same (or similar) situation have reported that when the ST16S is starting you have to press the Home button many times and at the end the DataPilot appears on the screen. Try it and see if it works for you.
marc13690
