Got a nice day in Colorado - took the Breeze out for a bit more testing. In Journey mode, I went out 100', 120' 140' and then noticed I lost the Wi-Fi signal - at which time I had no idea what the little drone would do. I had no camera link back to my phone. It completed it's task and came back home with no problem. I did this several times with no issue. When I got home I contacted Yuneec and ask them if "once programmed to do something in a programming mode" (Journey, Orbit, Selfie,...) will the Breeze carry out that task and return home EVEN IF the Wi-Fi signal was lost. The answer was "yes" - the GPS will guide the Breeze through the task and back again. The Breeze WILL NOT land in a Program mode (Journey, Orbit, Selfie,...) when the WiFi is lost - BUT if in Pilot mode and WiFi is lost it will land when and where the WiFi is lost. Makes sense.
I'd just like confirmation of the above from some of you seasoned pilots that may have done this. I will keep testing on my part but perhaps some of you have done similar and already know the answer (that the above is true)??
Thanks
Thanks
