Yuneec Breeze 4k no funciona con Android 12
Adquiri un Yuneec Breeze hace muchos años y solo lo probé y ha estado guardado desde entonces.
Ahora le he comprado una batería nueva y conectarlo con mi Xiaomi 11 que lleva android 12, el dron se conecta al Wifi, pero no hace nada de nada, lo intento despegar en modo piloto y nada.
Descargue una aplicación Yunne Breeze _camrelease 1.4.7.apk de un sitio de drones.
norte se si hay otra alternativa o hay que actualizar el firmware del Dron, o es que ya no funciona con este Android.
Agradeceria cusalquier ayuda sobre el tema.
Un saludo
I bought a Yuneec Breeze many years ago and I only tried it and it has been saved since then.
Now I have bought him a new battery and connect it with my Xiaomi 11 that has Android 12, the drone connects to the Wifi, but it doesn't do anything at all, I try to take it off in pilot mode and nothing.
Download a Yunne Breeze _camrelease 1.4.7.apk app from a drone site.
I don't know if there is another alternative or you have to update the drone's firmware, or if it no longer works with this Android.
I would appreciate any help on the subject.
Bye
The Breeze Cam app started having issues with the release of Android 8. The last update to v1.4.7 was in 2017.
You can try placing the phone in Airplane mode so it stops trying to connect to the internet then enable WiFi. Connect to the Breeze then start Breeze Cam. If you use the game style controller you will also need to enable Bluetooth so it connects to the phone.
The alternative is to find an older phone that runs an older version of Android that is still compatible with Breeze Cam. You can get the official version of Breeze Cam from Dropbox
Reactions: sanjas
@sanjas this link to my Google Drive also contains forum member modified Breeze Cam clones that allow you more freedom with the geo-fencing than the original.
Reactions: Pier2162
fotozone
